The main caps should already be stamped from factory. I put mine on a ring of bailing wire and sent them with the block for hot tank. everything else can be cleaned up at home. You'll just need some de-greaser and maybe a soda blaster for the pistons. Talk to your local machine shop, they'll probably also hot tank the heads for you at the same time.
As for bagging and tagging; everything you are going to reuse MUST be labelled as to where it came from especially valve train (lifters, push rods, rockers)
