I have an electric water pump on my lt1 wired to a 40a relay. I have a small white label “WP” on the relay and noticed its turning black. It is hotter to the touch than the others. Upon closer inspection the plug is beginning to distort, specifically the power wire that goes to the pump from the relay. I am getting power to the relay from the battery with a 20a fuse in the middle. And the trigger wire goes to the fuse block (fused as well - i want to say this one is only 5a) and comes on with the key. I do not believe my wires to be undersized. Does this indicate a bad relay?
