thanks alot ill give it a shot as soon as the sun goes down a bit81Regal said:There is 4 screws on top 2 under the speaker covers, 2 in the defrost vents. 3 bolts going up from the bottom, one on each side of the dash and one behind the radio. Also there is a bolt above the steering collum that holds the brace for the steering collumn that needs to be loosened. The wiring has several plastic clips that bolt on the back of the dash.
