Trying to remove my cluster to replace all the lights
Every video I’ve seen these are only connected with the 2 basic plugs you see in white in the pictures
Mine was held by a central plug that was held with a metal pressure clip I had to blind pry with a screw driver to loosen
Anybody know what this was?
It looks like a square shaped prong that goes into a hole that free spins and doesn’t adjust anything I can see on the cluster
Also
Once I had the cluster completely loose
It’s being held from coming out with a small metal cable (why is this even here?🤦🏻♂️) that I can’t get at without tearing my entire lower half open
(you can see the small cable in the second picture)
Anyone know of an easy way to remove this? Or if I can just cut it?
Also
