HELP Removing gauge cluster
Swindells
Jun 22, 2019
69
64
Trying to remove my cluster to replace all the lights
Every video I’ve seen these are only connected with the 2 basic plugs you see in white in the pictures
Mine was held by a central plug that was held with a metal pressure clip I had to blind pry with a screw driver to loosen
Anybody know what this was?
It looks like a square shaped prong that goes into a hole that free spins and doesn’t adjust anything I can see on the cluster
Also
Once I had the cluster completely loose
It’s being held from coming out with a small metal cable (why is this even here?🤦🏻‍♂️) that I can’t get at without tearing my entire lower half open
(you can see the small cable in the second picture)
Anyone know of an easy way to remove this? Or if I can just cut it?
Ribbedroof
4,938
7,090
Wellston, OK
Sounds like you're talking about the speedo cable and the shift indicator cable to the gear pointer
Drkuhar
515
919
Girard, IL
The speedometer cable, you push the metal tab in towards the cluster and the cable will pop out of the speedometer. Not sure on the indicator. I thought it unhooked from the indicator
Ribbedroof
4,938
7,090
Wellston, OK
Don't know why this didn't appear in my last post....
The shift indicator cable is clipped to the column lower shroud, and just slides off, after you remove the knee bolster (panel under the steering column)
ELCAM
1,127
1,277
The little tiny cable is connected to the shifter bowl on the steering column. Lay the dash back in and remove the screw from the steering column and slide the clip off.
ssn696
Living in the Past
5,551
6,704
Permanent Temporary
Scribe the spot where the clip is now so you can get it back onto the column in the same place.
The speedo cable plugs into the back of the cluster with a friction ring holding it from backing out. Reach up behind and pull the ring towards you and the cable should fall out with a gentle tug.
Swindells
Jun 22, 2019
69
64
And she’s out!
Thanks a bunch everyone 👊🏼👊🏼👊🏼
Time to replace all the lights and clean the inside of that plastic
SS_Malibu
1,185
2,091
Mesa, AZ
Oh, and if you haven't already done so, pictures, pictures, pictures, so you know how everything was for reassembly. Film is cheap nowadays. Just a blip on an SD card.
Swindells
Jun 22, 2019
69
64
The only thing that had a specific placement was the cable that connected to the column
Swindells
Jun 22, 2019
69
64
Has anyone ever tried to re finish the plastic on the gauge cluster?
Mine has a couple small scuff marks on the face and I’m debating on re finishing them like I did my tail lights
Just curious if anyone else has attempted it
Might try just going at it with the meguiars plastx and see how that looks first before taking any sand paper to it
