OLDS Reverse rotation Olds water pumps
rfpowerdude
674
1,076
Palm Bay, Fla
I had given away my last one to James as I thought I wasn't going to go the serpentine route. I have since gotten the itch to do the serpentine thing again. Since I have two Oldses, I figured that I'd get two more pumps. Even though the box says "new water pump", it seems they are rebuilt units. The two I got are two different castings.
And two different impellers
Here is one next to a stock Olds normal rotation pump
Obviously, the gasket is different and they both came with the correct gasket.
Are those serp kits still available? I can't remember who it was even though we communicated a few times over the years and I haven't done a search.
Anyway, I have two engines on stands and it would be nice to get the serp thing together...
rfpowerdude
674
1,076
Palm Bay, Fla
Now that I am looking at them more closely, are the impellers on the reverse rotation ones backwards? They seem to be the same as the normal rotation type even though they are supposed to turn the opposite direction.
Hope James will chime in with a pic of one the reverse rotation ones he has...
rfpowerdude
674
1,076
Palm Bay, Fla
I’ll get more detailed pics tomorrow and we can all compare
8,827
7,783
Larry Lorton and Pacific G bodies have the adapter brackets for Olds to use the sbc truck serpentine belt drives. When I pull the knocking 350 with the serpentine setup, I am tracing the adapter brackets. I may copy or will just buy another set in aluminum. Great part about buying another 88 to 95 350 TBI GMC truck to convert to Olds V8 power, it will have the necessary serpentine setup. I bought this Flowkooler pump and plan on another. I have one like your open impeller one, will keep as a spare. On the 424 especially, I want maximum cooling.
rfpowerdude
674
1,076
Palm Bay, Fla
Is this the pump?
It doesn't look quite the same as yours. What is the Flowkooler part number?
8,827
7,783
Is this the pump?
Yes, that is it. I waited a month, another member on here waited even longer. Supposedly the wait was on a casting for them to add their impeller to. I'm not sure why the back picture is wrong.
rfpowerdude
674
1,076
Palm Bay, Fla
I guess I could send the two castings I have to them and have them press the old impeller off and press the new impeller on.
8,827
7,783
If there is any delay when I want another, I may do the same. Yeah, you are dealing with two harder to cool motors in Florida. How much the closed impeller helps is questionable but Olds used it in all heavy duty cooling applications.
7,989
18,702
JAMCAR223 , your input is wanted in this thread.
