Well I been waiting for the pickup tube that hasn't arrived. So I started messing with the harness. I used lt1swap.com pinouts/ info. I have the driver injectors,coil,02 sensors on 1 fuse, the pass side injectors, coil,02 sensors on another. Then all the other pink wires on the 3rd. It was a bit intimidating until I dove in.
I have the a/c circuit bundled up for when I add it in. The cruise circuit is off to the side and all the sensors,obd and switches are off in there own bundle
I spent about 8 hours on it. Very tedious figuring out what's what, checking continuity, labeling and removing wires. I have a pretty good handle on how everything gets hooked up. And since I was already irritated I decided to replace the motor mounts.
If your doing this, go buy a 15 mm swivel from the start. That bottom bolt is a beootch without it. The top bolts are easy. Just use the box end of a wrench in the frame and a ratchet out of it. Don't use impacts and use the top ratchet to loosen. If you use the ratchet in the frame to loosen it'll keep falling off.Also there's a top and bottom. The above pic shows how to install it upside down. Many profanities were used during this process. I also lost one of the nuts. I'll buy one tomorrow. This is my least favorite part of this so far.
If the pickup tube comes tomorrow, I'll be putting the drivetrain in and building my crossmember. I made a list of parts needed to finish the swap with $$ next to it. Mistake. I figure another 2k in parts not including tuning. Most that's the converter,headers and fuel module. When it's all said and done I'll have 3k in parts not including the drivetrain.So I'm thinking the only cheap ls swap is a bone stock swap(although I know alot of guys spent 5k on a 355 build). It's not particularly hard but I also wouldn't call it easy.
