I let my boy pick the engine color(nothing is on sale)
He picked ford blue. It was 75 today so I broke out the pressure washer on the engine. Used some degreaser that was probably unnecessary. It was mostly crusty paint/rust. I got it pretty clean and I'll paint it tomorrow since it'll be 70 again. After I cleaned it.
My truck had oil cooler lines, that I bent when I pulled the engine in the dark. I'm not sure if I should run them or not. I also pulled the water pump,ac, and harmonic balancer. I had to use the Chrysler balancer puller. I'll swap the cam tomorrow, I started to pulled the front cover so I could easily use the TDC method to change the valve springs I had 2 bolts out when I realized i didn't drain the oil.. disaster averted.The heads were clean, no sludge or grime. Definitely cleaner inside then out.
I used the Lisle valve compressor,magnet and pick. It works, just lube it up often but it takes forever. I'll buy the tool that does 2 at once next time.
I also need to find out how to fix this from leaking.
Next on the list is the cam,oil pan and harness.
