I'm gonna upgrade (or down grade depending on how you look at things) to an almost stock 350 olds or a 403 since my street/strip 350 is done for. I'm basically taking the top end off of my old 350 (manifold, distributor, valve covers, crankcase breathers and 4 corner cooling) and throwing these parts on the new one and I want to use my 7111 small block olds performer rpm manifold on the new motor over the stock cast iron unit. I dont think I'm going to use the 4150 750 cfm holley double pumper off of my old 350 because I'll be driving the car more on the street than before and I'm thinking of getting a remanned quadrajet for the 350, the only thing is I dont know if it will physically bolt on the manifold or even fit right without an adapter plate. So my questions are- Can I get away with using the RPM manifold and qjet without an adapter plate? And If so would a spread bore carb spacer work correctly with the manifold/carburetor?
