OR THIS "EPOXY" : https://www.homedepot.com/p/Rust-Ol...loss-Black-Epoxy-Spray-Paint-263376/205756160
"No Primer Needed"
"No Primer Needed"
@fleming442
I do not know if this guy is kidding or what. He's always stating things that are wrong, then his comments cannot be seen when I log in. He said "Epoxy Satin" > "Absolute Joke"
Don't ask for help then slam someone because you don't like their answer.
You might as well tremclad it, seems like that's right up your alley
I've been using PPG semi-gloss lacquer that I've horded over the years but thats my way (good cleaning, self etch primer, lacquer.) Simple/easy fix-engine enamel, good enough for the block, good enough for everything else.
I like to use self etch primer to make sure I have a base that has a good bite in the bare metal & what paint may be left. Depending how things look I may use a high build primer to level things out or regular automotive to ad as a build coat. For the Rustoleum it would be OK but if using the engine enamel I'd use the matchig primer.
