Has anyone had a problem with random smoke coming out the vents but get out of the gas it disappears, and put slider on the cold side. :? Its never done this before and i was driving about 70mph it smell like oil or some type fluid.
90hurst/oldsguy said:Has anyone had a problem with random smoke coming out the vents but get out of the gas it disappears, and put slider on the cold side. :? Its never done this before and i was driving about 70mph it smell like oil or some type fluid.
check to see if you've gotten a oil leak spring up on your v/cover gaskets... sounds like you may have some of the burn-off smoke getting past the cowl rubber and into the a/c intake... don't know why the smoke would only appear on one side of the heat/air settings though...90hurst/oldsguy said:it was more of a oil smell
