Source for Quick Ratio Boxes? New/Used
6,829
6,736
What cars have a bolt in better ratio power box? Not necessarily f41 spec but better than stock. Or part number for new/reman.
19,992
Late Model 12.7:1 quick-ratio gearbox
ID markings YA, WS and HX
Line Thread Size: M18x1.5 and M16x1.5
Number of Mounting Holes: 3, (missing leg H-pattern)
Input Shaft Diameter: ¾-inch
Output Shaft Diameter: 1 ¼-inch
Number of Turns Lock to Lock: 2 ½ - 3
1984-'88 Monte Carlo/Malibu with Z65 suspension
1983-'88 Malibu, El Camino
1982-'92 Camaro except FE1 soft ride suspension
1984-'87 Regal with FE2 or FE3 sport suspension
1983-'84 Hurst/Olds
1985-'87 Cutlass with 5.0 (VIN code 9)
1982-'85 Trans Am
1986-'92 Firebird except FE1 suspension
1986-'87 Grand Prix with FE2 touring or F41 heavy duty suspension
Pre-'76 12.7:1 quick-ratio gearbox
Line Thread Size: 11/16 x 18 and 5/8 x 18
Number of Mounting Holes: 4, (H-pattern)
Input Shaft Diameter: 13/16-inch
1967-'76 Camaro, Firebird
1970-'76 Monte Carlo/Malibu
1964-'76 Chevelle
1977-'79 12.7:1 quick-ratio gearbox
Number of Turns Lock to Lock: 2 ½- 3
1977-'79 Camaro, Firebird
1977-'79 Monte Carlo, Malibu
1977-'79 Chevelle
Jeep/S-10 14.0:1 quick ratio gearbox
Number of Turns Lock to Lock: 3 - 3 ½
1991-'92 Fleetwood
1992-'95 Grand Cherokee
1984-'93 Comanche
1984-'95 Cherokee/Wagoneer
1983-'86 Bonneville
1982-'93 2WD S-10 Blazer and pickup
Weatherhead conversion fittings
(from your local auto parts store)
Part number M41157X6X16 - AN6 male to metric 16 O-ring male
Part number M41157X6X18 AN6 male to metric 18 O-ring male
Part Number 1446 - female inverted flare thread
(5/8-18) to male 16 X 1.5 metric o-ring
Part Number 1447 - female inverted flare thread
(5/8-18) to male 18 X 1.5 metric o-ring
Part Number 1444 - 11/16-18 thread O-ring
Male to 5/8-18 female inverted thread adapter
  • Useful
Reactions: 12 users
20,391
make sure the rag joint and all your steering components are in good shape, if there is play a new box won't cure that
gnvair
1,102
1,305
You can try Rock Auto for part numbers. For example; Look up 1988 Monte Carlo SS, 1989 Pontiac Trans Am, etc. Just keep in mind non G body boxes will have different internal stops which can cause differences in the turning radius
19,992
Go to a chain store or internet store like rock auto and put in one of the cars listed.
You want us to install it too?!?!?!?!?!?!
street sweeper
204
264
Central Indiana
No but it gets tedious having to find gm part numbers and verify that the gm part number is in fact that of a quick ratio box, then finding a replacement part number assuming it is the correct part and there was no error in any of the listings. Because i have done the "just buy it for this vehicle!" and gotten bit in the *ss. I just figured maybe somebody had done the swap recently and could pull up an online invoice showing the part number and brand but i apologize for trying to seek redundant verification of part numbers.
Thanks for the assistance!
6,829
6,736
It's gonna be part of a mass upgrading. Balljoints, bushings, tie rods, jeep shaft, etc.
