Ok guys, I got over to the storage last night and got some pictures. First up, here's a look at the driver's side header from up top. It went in with no difficulty and I don't have any clearance concerns on this side....
I know it looks close on the rear edge of the upper control arm but it isn't. I'll try to remember to get a picture from the side.
Here's a look at the passenger side from up top....
This angle shows that the tube for the front cylinder on this side is very tight to the rear edge of the upper control arm, though it is not as bad as this picture makes it look. The bolt is lower and is not a concern...
Here is a look at the relationship of the driver's side collector with the clutch fork. I don't see any problem here. We'll see what I say when I try to get the clutch equalizer (Z-bar) in there....
Here is a look at the passenger side collector. You can see that the collector is pointing towards the passenger side of the car. I'm convinced at this point that this was deliberate to provide clearance for the stock style starter. I have a smaller Powermaster starter so I don't think I'm going to have any trouble getting it in there....
Here's a look at the biggest clearance problem. The collector is hard against the lower control arm mount on the passenger side....
I was over at the storage for about three hours and I did quite a bit of trimming. I trimmed the rear edge of the upper control arm and I trimmed the lower control arm mount. I had the header in and out of there two or three times. If you look at that coating cross-eyed, it scratches. At this point the collector is not up against the lower control arm mount but I have a little more trimming I want to do before I paint the bare metal.
The other issue is clearance between the passenger header and the brake line. The instructions say to move the brake line from the back of the crossmember to the top of it. I'm having some heartburn from this since I have a new stainless line that fits well and I don't want the end result to look like a hack job. I may have to bend my own brake line, or make a new section and join the two with a flared union fitting. Here is a look at how tight it is. Keep in mind, these views are from under the car looking up...
I bought some thermal insulation from summit that has a foil looking outside and a Velcro seam on it but I think the line is just too close for that to be effective here. Your thoughts?
I'll include some pictures of the trimming when I'm sure I'm finished. I hope to get over to the storage and finish the trimming tonight. Then I'll make a decision on the brake line. That's it for now. Thanks for looking in.
Oh, and I don't know if anyone noticed but I've been reducing the file size of the pictures on the last several posts so these pages will load faster and use less data. I hope it helps. Thanks guys.
