Since this project has drug out for so long, I thought it would be helpful if I did a quick recap, mostly in pictures...
I bought the car in September 2014. I joined the forum about a year later. Here's what I started with....
The car had a SBC 400 and a Saginaw four speed in it. It was sort of fun to drive. It had originally been a diesel/automatic car and the swap was a total hack job. It leaked everything like sieve. I really regretted buying the car, initially. This is probably what it looked like when it rolled off the line....
I took the car apart in December of 2014. I initially was going to reseal and repaint the 400 but came to the conclusion it was worn out. It had already been overbored 0.030" so I sold it in favor of a crate engine....
It's a 350 SBC. It's a two-piece rear main block with the provisions for a mechanical fuel pump. It has Vortec heads on it and a mild Lunatti cam. It's rated at 350HP/400 ft. lbs. if I remember correctly. I bought it from Pace Performance.
Sometime around March of 2016 I finished up the front suspension rebuild and Blazer brake swap. The front suspension and steering is all Moog stuff and is stock with the exception of the 5660 springs. I also swapped to a quick ratio (F41) gearbox...
Next I went to work on cleaning up the firewall and reconditioning the HVAC case....
Then cleaning and painting the rest of the engine bay....
The engine was still at my house, but was pretty detailed on the stand....
At the end of 2017 I replaced the power antenna, painted the inner fender wells and the engine compartment was starting to come together....
The engine went in right at the end of 2017....
Followed by the T5. I'm using a WC T5 out of like a 91 Iroc. I'm using the 83 Camaro mechanical linkage bellhousing. I have a Centerforce clutch in there. In this picture, the trans is just sitting on the G-Force 700R4 transmission crossmember as the middle section is way too tall....
To be continued---->
