Depends on the cylinder- most are 8.5, a couple are 9.3, and 1 or 2 are 7.95What compression will you end up with?
Some 454's have that entire compression range on one bank......Depends on the cylinder- most are 8.5, a couple are 9.3, and 1 or 2 are 7.95![]()
Well I did spend 6 hours driving and 12 and 1/2 cutting one weekend to get a bad one and the one I'm using was in my shed the hole timeYou're doing it all wrong. You're supposed to use all your time trying to get a blowed up engine running before finally being resigned to the fact that you need to rebuild it! Good luck with the grind this week sir!
And you know if you just started with the one in the shed you would of still drove out to the free lands but it would of been 18 hours cutting it out.Well I did spend 6 hours driving and 12 and 1/2 cutting one weekend to get a bad one and the one I'm using was in my shed the hole time
Didn't know you were into fat chicks. They need luv, too!!!!!No welding supply. She cought me nothing going to get done today. So I'm off to Cape May with the fam taking Lauren Lexie and Janet whale watching should be fun
