The time has come for me to repair and install my 454 Eric needs the loaner 454 back so I'm looking for a reasonably cheap fix for mine to get it back on the run stand. As you all know I'm not real happy with what happened with my comp cam and lifters. This time I'm thinking about using a summit racing cam And lifters because it's only like $120 but I'm loosing my mind trying to figure out what springs to go with and maybe that's not even the cam I should use? So let me ask you guys what would you go with in a hydraulic flat topic cam and lifters? The build is all here in the thread. In short it's a rotating assembly from a 90 V3500 stock rods and stock dish pistons the heads however are closed chamber large oval port 1965-66? 396-427 to up the compression and the intake manifold is a performer. The truck dose have long tube headers full dual exhaust th400 stock converter and 4;10 gears. I know little to nothing about what the compression ratio actually is or about spring pockets stuff like that. So I'm asking you guy's what would you go with? And what springs would you use for it? Bear in mind I cannot afford to do a retrofit roller.
