I just recently got my 80 Malibu running, but I am now having probelms with the starter. The car has a 383 stroker SBC with a 168 tooth flex plate and a mini starter to match. Most of the time the motor starts no problem. The issue I have is that sometimes the starter sounds like its grinding :? . It does not happen all of the time so I cannot really jack it up and look under it to see whats going on. Sounds just like a starter would sound if you had the motor started and turned the key again, but when it does it, the motor is not started yet. Any help is appreciated.
