- Aug 2, 2021
- 1,120
- 63
Tore down my steering column to replace my ignition actuator rack and reconnect my rod so I can finally start my car with my key...
I'm down to removing just one pivot been before I'm able to remove the ceramic housing cover covering the actuator rod and rack.
I used the pivot pin remover tool from NAPA, and the second tool broke inside of the pivot pin (first tool broke too, but not inside pin).
How do I remove this broken piece inside of the pivot pin ?
Dremel cutting wheel and flat tip screwdriver ? Hammer and chisel to pry out the pivot pin itself ?
