i can't answer his question on that particular gear. i can comment on the f41 mcss style 800 series gear.I'm anxious to hear answers to CrackedHead's question too. What do people who have made the quick ratio swap think of it? Did it rock your world? Inquiring minds want to know!
Cheers - Gary
i replaced both of my '79 calais variable ratio steering gears with 800 series steering gears from iroc camaros. i liked the feel of the variable gears but i didn't like the variable part. they are quick in the center but get slower the farther you turn from center. the iroc gears are 12.7 to 1 ratio and have a slightly reduced turning radius so my big tires won't rub on the wheel wells.
i did the same with my 78 salon, that had the 605 series gear, the feel was very sloppy. i put an iroc gear in this too, so all three cars feel and act the same.
my dad purchased a salon new in '79. pretty much a base car. he hated the steering on that car from the day he brought it home. after a couple of years of putting up with it, he finally started checking around with local shops, this is how it was done before the internet. he found out he had the 605 gear. so he went to the junk yard and got an 800 gear from a g-body and swapped them. he was very happy then. the car felt completely different. it wasn't sloppy or wandering around on the road.
my recommend is this, if you have a 605 gear, replace it, with anything else. its worth the time.
also, verify your steering linkage is good, including your idler arm. gm spec for looseness on the idler arm is ridiculous, it like 1/4" of play or something. if there is play, replace it. moog makes a great idler arm.
joe.
