strange brakelite problem
Discussion in 'General Discussion' started by cherokeechief79, Jun 26, 2017.
  1. cherokeechief79
    cherokeechief79 Apprentice
    Jul 21, 2008
    94
    15
    8
    nj
    i fired my new project up last nite and all went well .its an 84 non ss.
    my problem is that the driver side brakelite is on all the time.the pass side works fine as it should though.
    I don't know if was like this before because I didn't have it on the road befor the engine swap and I cant contact the po.
    i did change the steering column from a non to a tilt.
    any ideas?
  2. wonderboy24
    wonderboy24 Royal Smart Person
    Jul 10, 2012
    1,130
    461
    83
    Davenport, Iowa
    could be a bad brake lite switch.
  3. cherokeechief79
    Jul 21, 2008
    94
    15
    8
    nj
    could that make just one side react the way it is?
  4. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,802
    2,959
    Kitchener, Ontario
    does the turn signal work on the left side?
  5. Jeff L
    Jeff L Master Mechanic
    Nov 20, 2016
    477
    355
    Southern AZ
    Might be some kind of short that is keeping that side activated all the time. I had a similar issue on my Buick Apollo many years ago and if I remember correctly an exposed wire was touching another one that was not covered enough at the switch. What makes me think this might be happening to you is you changed the steering column.
    Recheck you wires and then the switch.
    • Agree Agree x 1
  6. tc1959
    tc1959 Comic Book Super Hero
    Dec 23, 2009
    3,679
    608
    Surprise AZ.
    Change the bulb.
    • Agree Agree x 1
  7. 1evilregal
    1evilregal Royal Smart Person
    Apr 23, 2009
    2,004
    786
    Greensboro, NC
    quite a few GM products use the same power feed for the brakes and turn signals.... I agree with Jeff L, I'd start at the column, since you switched that out.... was it from a same year/model car or different year/model?
  8. Jeff L
    Nov 20, 2016
    477
    355
    Southern AZ
    I was talking with a friend of mine about this because he has had experience with electrical problems with all the cars he builds. Some of his suggestions are to check all the lights when you have on the emergency flasher button. Turn off the flashers and try the left and right signals to see what happens. Stop that and see what happens when you put on the brakes. This is to rule out one thing over another. Electrical problems are as frustrating as finding vacuum leaks!
    Some things that can cause issues are the wrong bulb, a short, a bad turn signal stalk, crossed wires, faulty connector, bad brake switch.
    Hope some of this helps.
    Plus did this problem only start after you changed the column? I still think something in there is fouled up.
    Good luck with it.
    • Like Like x 1
  9. cherokeechief79
    Jul 21, 2008
    94
    15
    8
    nj
    just had a chance to look quick last nite at it but heres what I found.
    lites on.......normal pass side brake lite on dr side(appears the wrong filament is on though)
    brakes w key off....pas side ok dr side running lite comes on
    key on....dr blinker blinks but seems to be on the wrong filament.
    emergenct flasher works but driver seems to be on the wrong filament.
    all of the bulbs seem correct and in good shape.sockets too.
  10. pontiacgp
    Mar 31, 2006
    21,802
    2,959
    Kitchener, Ontario
    if the wrong filament is coming on it's either the bulb is in backwards or someone has reversed the wiring
    • Like Like x 1
Loading...
Similar Threads - strange brakelite problem Forum Date
Strange noise... General Discussion Dec 12, 2017
Strange Center Consoles General Discussion Feb 27, 2016
Strange troubles General Discussion Nov 20, 2011
Strange Ticking General Discussion Jul 12, 2011
Strange craiglist find General Discussion May 11, 2011
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
