Just like the title says, every now and then when I punch it the car will get stuck in full throttle and I'll have to use my e-brake, switch to Neutral, and keep my brakes slammed until I can navigate somewhere safely to stop. For a while it went away when I replaced the throttle return spring, which good god it needed, but then about 6 weeks after I punched it and the throttle got stuck again. Every time this would happen I would have to remove the air filter, pull the throttle some and it would retract to its closed position. I'm learning bits and pieces here and there, but what can I do to keep this from ever happening again, and save my own life as well as the Cutty's.
Car is a 1986 Olds Cutlass Supreme
307 VIN Y V8
stock Rochester 4bbl quadrajet carburetor, no longer CCC, i guess its just electric now that there's no computer?
the 307 is already a dog, I wanna at least be able to punch it without the potential of crashing!!! 😛
307 VIN Y V8
