Suck N Blow Monte
You removed the regulator from the unit?
Results are in!
Don't take the numbers to heart. My compression gauge is not the most accurate. Number one is dead. Took the valve cover off that side. Don't see anything wrong there. Have to pull the head and take a look.
Yeah, if it's just rings you can hone it, re-ring it, and send it.
We will see. Once I get the left head off I will figure out how bad it is. If I can rering it I will. If it needs bord I probably will not rebuild this engine. That money would be better spent on a newer engine. (Series two)
Is that the factory longblock that was in it when it was carb turbo?
Reactions: motorheadmike
rip
idk if they still have it but yaws auto salvage near where i live had an 83ish electra with a 4.1
