454muscle said:Since you asked to explain myself further. I answered respectfully, not to insult you by the way. So calm down.axisg said:Thank you for the grade 6 science lesson "bro". So I propose that you explain yourself further. How did the sugar dissolve ( even though its been proven that suger does not dissolve in gasoline ); then sneak past your sock and fuel filter, then re-appear as sludge in your carburator ? Your are theorising that the sugar went from a solid, to a liquid ( to get past your filters ) then "re-appeared" as as a gel or semi-solid in your carburator.
"If" the gasoline were able to break down the "Crystalline" sugar molocule strings to make a fine enough "solution" containing parts of both gasoline and sugar it would need to be fine enough to pass through both the sock and the fuel filter. Then, at that point what other factors could possibly be introduced in your carburator ( and just past the fuel filter I might add ) to mysteriously change this "solution" of gasoline and sugar from the fine liquid that just passed the filter to produce the gel or sludge you describe and not be injested into the motor and burned up ?
Bottom line; If the fuel filters were in place they would have blocked the flow of 99% of the foreign contaminants. Maybe someone dumped another chemical in your tank which will combine with gasoline to make sludge but it was definately not sugar.
Do you even know what a solution is? It's not grade 6, it's grade 11 actually. When a crystal dissolves in a liquid, there are NO solid particles. That's all I was trying to say. That's a SOLUTION. I didn't say it dissolves in gasoline. Maybe in the water or the alcohol in the gas. There are no "crystaline particles" that have to be "small enough". A solution of sugar or salt or any mineral can leave traces on a solid and begin to crystalize -- this is how crystals are formed.
I am not insulted, I just didn't apprecialte the sarcasm connected to the science lesson comment since you provide no science in your theory.
How do you explain the sugar going from a crystal when poured in the tank, to a liquid with apparent sugar particulate fine enough to pass thru the filters, and back to a semi-solid or gel as gunk in your carburator, when sugar and gasoline will not mix to make a solution to begin with ? Further how do you remove the gasoline from the mixture to reduce the solution to a gel or crystal in your carburator ?
If you mix salt and water together the solt will dissolve into the water and make a solution. Sugar and gasoline will not mix together to make a solution. So how does the sugar make it from the tank to your carb ?
