pontiacgp said:sugar in gas is older then I am so if sugar ruined engines then I'm sure you don't have to email myth busters to get them to redo their "research".....it would be all over the internet if it was true that sugar ruined engines but what you have is some guys telling us it ruined their engine....sugar does not dissolve in gas so how is a sugar crystal supposed to get through the filter even if it travels that far?
exactly !
Sure sugar in the tank is a PIA. If you let the tank run low enough it will clog the sock in the tank, and if it gets past the sock it will get in the lines and clog the filter before the carb. Then you have to drop the tank and flush the lines ( same as you have to do if your gas tank that has rusted from the inside out ). So if you have no sock in the tank and no filter before it hits the carb then there is a possiblity you will end up with damage.
But to think that a crystal ( like sugar or salt or sand ) will dissolve to sneak "ninja like" past the sock and filter then suddenly reaapear as sludge in your carb and seize up your motor, nah doesn't make sense to me. I am no scientist but I have had to drop a couple rusty gas tanks.
