Suggestions on 87 pontiac swap
2
I have a v6 engine I wanna swap in my 87 Pontiac Grand Prix for what size engine could I go with? I want a bit more power
Andebe
241
256
Indiana
Small block Chevy is probably the cheapest,IMO. How about a Poncho 400?
MrSony
6,831
6,741
Des Moines, Iowa
If the distributor is in the front, you have a 231 Buick V6. A Buick 350 (also distributor in front) is literally a drop in swap. Same mounts, wiring (might have to elongate some wires), starter, water pump, fuel pump, bracketry, etc. Fits nice too. If it has a distributor in the back, just plop a chevy 350 in it. Personally I'd go pontiac. 350, 400, 455, you're pick.
454GrandPrix
429
818
Lehi, Utah
I was like you once. I removed my Grand Prix's V6 and swapped in a big block 454 Chevy. Even with my stock iron heads, I quadrupled my car's horsepower.
Go big or go home!
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Cheapest and easiest would be a Chevy 350.
Plenty of power for the money.
But a 400 or 455 Pontiac would be sweeeeet!
Reactions: 4 users
MrSony
6,831
6,741
Des Moines, Iowa
Go big or go home!
Pontiac 455 is bigger :p
565bbchevy
9,614
12,683
Michigan
A Pontiac engine would be nice if you can find a good running one otherwise on a budget the SBC will be the best bang for the buck and is still available as a new crate engine with a warranty.
Wageslave
1,750
3,341
350 Chevrolet - Good
400 Pontiac - Better
455 Anything - Amazing
  • Winner
1evilregal
3,056
4,357
Greensboro, NC
in 87, (not sure about other years), the only gas powered v-8 offered was a small block chevy 305... if you could find someone parting one out, you could have a one-stop shop from mounts to carb, with a fairly simple drop-in...
  • Disagree
