Mind sharing some specifics about the heads combo on those? I know they are eldelbrock BBO heads, but are they milled, what springs & rocker setup, ect.
Thanks!
It looks awesome!
Thanks!
It looks awesome!
I had a shop order and build the motor. Its bored .030 over full roller. Rockers arms are 455 7/16 1.52. All Comp Cams pushrod and rocker arm kit as far as I know.Mind sharing some specifics about the heads combo on those? I know they are eldelbrock BBO heads, but are they milled, what springs & rocker setup, ect.
Thanks!
It looks awesome!
I dont know I know nothing about how to build a motor. Out of my league for now.Weird, factory ratio is 1.6, wonder what those rockers are for sbc?
Ok I see. Do you think I would notice a difference? More lift seems better but IDK 🤷🏿♂️As long as the pattern is good and pushrod length is right, they should work fine. You will have less lift than advertised as Olds cams assume a 1.6 ratio.
