Supreme Speed Salon (87 T Top Salon build)
81cutlass
4,649
13,565
Western MN
Mind sharing some specifics about the heads combo on those? I know they are eldelbrock BBO heads, but are they milled, what springs & rocker setup, ect.
Thanks!
It looks awesome!
SupremeSpeed
596
802
GA
Thanks!
It looks awesome!
I had a shop order and build the motor. Its bored .030 over full roller. Rockers arms are 455 7/16 1.52. All Comp Cams pushrod and rocker arm kit as far as I know.
8,823
7,775
Weird, factory ratio is 1.6, wonder what those rockers are for sbc?
8,823
7,775
As long as the pattern is good and pushrod length is right, they should work fine. You will have less lift than advertised as Olds cams assume a 1.6 ratio.
SupremeSpeed
596
802
GA
Ok I see. Do you think I would notice a difference? More lift seems better but IDK 🤷🏿‍♂️
8,823
7,775
I was just going through this thread but haven't found the cam specs, what are they? Your heads move serious air, around 260 CFM and 190 exhaust with a much better chamber design. I say 1.7 rocker arms but it depends on the cam, those heads will take .575" lift.
19,992
What does the cam call for?
8,823
7,775
  • Wow
