Remove the spacers from the rear & you don't need to worry about how to raise the front. Removing spacers is free.If my suspension was bad or failing, what symptoms would I be experiencing ?
Seems as if I have coil spacers in the rear suspension but nothing in the front...how can I raise my front suspension to level with my rear suspension ?
Check BJ play by rocking the top/bottom of the wheel w/the suspension off the ground. Check the steering linkage by rocking the wheel @ the sides (front/back side of the front wheels) to see if they move /have play.How about my steering linkage ? Does it look good ?
That is a factory reinforcement bracket for the frame to crossmember. There is one on each side in the same spot of the frame.
I honestly do not see spacers on top of your rear springs....
I want a little lift on the suspension... I'm 6'2" and would rather climb in and out, than fall into my car and climb out lolRemove the spacers from the rear & you don't need to worry about how to raise the front. Removing spacers is free.
Side to side moves (video) and up and down is solid...Check BJ play by rocking the top/bottom of the wheel w/the suspension off the ground. Check the steering linkage by rocking the wheel @ the sides (front/back side of the front wheels) to see if they move /have play.
Ok, making sure it wasn't aftermarket reinforcement modification.That is a factory reinforcement bracket for the frame to crossmember. There is one on each side in the same spot of the frame
Hell yea...Ok where can I find the taller springs you're using for the front ?I can help you here. Here's what I did. I replaced the springs in the front with some taller springs with the same spring rate as stock, added about an inch, then replaced the rears with variable rate springs and used some poly isolators on the rear to get the ride height level. I'm 6ft 6in, so I know your pain.
Gotcha 👍🏾From your picture of the rear spring, that's just to keep the spring centered on the frame, it's not a spacer.
Yea that's what I'm being told and originally plan on doing (replacing all of it), just wanted to get a second opinion...If you have over 100k miles on the car, and don't know the history of the suspension, it would be, relatively, cheap insurance to go ahead and replace everything, as budget allows, starting with ball joints, bushings, springs and shocks, then moving to the more easily accessible parts, like drag link, tie rods and idler arm.
Also, your sway bar end links look really loose.
