CUTLASS Swap 3.8 with 383 stroker
Zzz
116
16
Tennessee
I have an awful time trying to figure out how to ask questions and post and reply and all this other stuff does anybody have any idea which way the center link goes on my 86 cutlass supreme
Zzz
116
16
Tennessee
It only fits one way. inner tierods poke through in a forward direction and the ends angle down, I think.......
Another question about the heat and air part under the hood the guy who had this before me cracked the outer case pulling the engine out I guess should I fix that or is that part readily available
Zzz
116
16
Tennessee
And that’s a big hole on the bottom where the shadow is
9,618
12,703
It could be repaired with fiberglass but plenty of people pull the casing off thinking they don't need ac or heat ever again so you should be able to find a used one also.
Zzz
116
16
Tennessee
OK thanks man I’m on it. I’m trying to keep it stock as possible
Zzz
116
16
Tennessee
Another question for you guys should I use a three row radiator or is a two row going to be sufficient for the 383 stroker. I just appreciate a bunch all the responses that I get.
Were can I find a stout 700r4. My engine is done and need to move into the next phase.
