Im pretty sure it is the same length as a TH350Isn't the T10 pretty short to begin with?
Thanks for the response. My question was if there is a known shifter (for the T-10) that can be used in conjunction with the factory 78 bench seatT10 bolts right in were a th350 would length is slightly different on the drive shaft
I installed a Muncie M20 (same dimensions and shifter mounting as a T10) and used a hurst comp plus Part # 3913780 with 81 Lemans bench seat.Thanks for the response. My question was if there is a known shifter (for the T-10) that can be used in conjunction with the factory 78 bench seat
Awesome thank you. I like the pic too it looks great! Is your m20 a wide ratio and how do you like it?I installed a Muncie M20 (same dimensions and shifter mounting as a T10) and used a hurst comp plus Part # 3913780 with 81 Lemans bench seat.
It's a shifter designed for a 55-57 chevy bench seat
There was much more clearance to the seat than I thought , so for me it actually sat too far forward and needed to be modified!
Looking back I'd be tempted to try something like the Hurst # 3916848 shifter which looks like something for a late 60's nova.
Can't make any guarantees though so experiment at your own risk!
Great link thank you. I thought the t10 was very similar to the m20?The G bodies never came with a Super T 10 so no. What you need to look at are the handles find one that fits a T-10 shifter mechanism and will clear the seat.
https://www.shifterdoc.com/Hurst_Replacement_Shifter_Handles.pdf
5384331, 5384078, 5386900, 5388620, 5389016 look promising.
