That's exactly how I did it, mocked it up with a small piece, then marked it, welded it, and heated up the middle with a cutting torch and bent it to where it was exactly where I wanted it.
I did not use setback mounts with this swap so everything came out pretty much perfectly, normal engine placement the Transmission will be 1" toward the rear more.
