Hi guys,
I come back to you because my tachometer problem is still not solved.
Here is a video of my problem :
So I have wired directly the 3 bolts of the tachometer to the plug to be sur that there is no bad electrical connexion.
- The power wire is working because I have 12.7V between power wire and the ground wire
- I think the ground wire is OK because the others gauges work (more or less) and they share the same ground.
- The tach wire should be Ok because it worked 1 week ago...
So what could it be ? Is the tachometer itself dead ?
The needle still moves if I touch the part where the jumper goes (and where I have soldered a piece of copper). But it has no relation with the the speed of the engine..
Help! Thanks in advance!!
