axisg said:check the wire to the sensor, they have a bad habit of coming off and burning up on the exhaust manifold.
Probably near the exhaust manifold :idea: Sorry, I couldn't resist :lol:digimurda said:axisg said:check the wire to the sensor, they have a bad habit of coming off and burning up on the exhaust manifold.
ok, where is the temp sensor located?
RITTER said:Probably near the exhaust manifold :idea: Sorry, I couldn't resist :lol:digimurda said:axisg said:check the wire to the sensor, they have a bad habit of coming off and burning up on the exhaust manifold.
Should be in the head
So, it'll be near your headers. There should be a sensor screwed into the head (if it's on the drivers side it'll be toward the front, passenger side toward the rear) To my knowledge that is where the factory temp sensors are located. Could also possibly be located in the intake manifold 8)digimurda said:RITTER said:Probably near the exhaust manifold :idea: Sorry, I couldn't resist :lol:
my car has headers though...
RITTER said:So, it'll be near your headers. There should be a sensor screwed into the head (if it's on the drivers side it'll be toward the front, passenger side toward the rear) To my knowledge that is where the factory temp sensors are located. Could also possibly be located in the intake manifold 8)digimurda said:RITTER said:Probably near the exhaust manifold :idea: Sorry, I couldn't resist :lol:
axisg said:sorry didn't notice you had a 442
On the SBC the temp sensor is between cyl 1&2 on the DS. The wire often melts or falls onto the exhaust manifold and burns up.
The SBO had 2 sensors in the intake manifold IIRC just above the water pump on the DS close to the thermostat. I think one was for the guage and one for the CCC system. Break out your test light and see what you find.
