That would be wise.I am still thinking of flying you out here to work on the Monte.
I put about three hours of effort into the passenger side trim piece earlier this week. I started with 320 and then 400, 600, 800, 1000, 1200, 1500, 2000 and finally 2500. I did all my sanding in the long direction of the trim and got much better results. I then did the Mother's mag and aluminum polish with the foam cone in the drill. It's pretty good but it isn't show quality. I'm guessing the Mother's isn't aggressive enough, or maybe the foam cone isn't.Progress! I had success “restoring” aluminum wheels in my past finishing with 2500 grit before polishing. It’s obviously a different substrate, but with stainless being a harder material you probably need to knock the scratches down more to get a more mirror like finish.
Thanks Darin. Yeah, fixing the automatic level control system hasn't been as easy as I thought it would be, and it's been pretty expensive. Once I'm done, all that will be original will be the wiring and the air lines. I'm still trying to buy a refurbished level control sensor. Still, I want this to work. When the back of the car gets loaded down with passengers and luggage, I want the ride height to be correct.love the progress on the car, will def be one of the nicest Roadmonsters out there!
I'm kinda going through the same motions on the caddy, with the rear air ride suspension, and dealing with the P.O.'s mechanic's f*#kery... wrong air struts, mounted wrong, no resistors for the aftermarket strut's lack of wiring harness... found some Delco struts, and seem to be working, but oddly not sure, as the butts of these big girls sit low anyway! looks like the Roadies use the same type stuff in their workings, just different shapes, and the compressor look to be the same unit as mine... I'm tuned in for the final results!
I'm not sure the compressor is kicking in and airing up the system. I actually learned on sunday, that the system on mine is different from a standard Deville.. the normal system has only 1 sensor on the D/S rear, where my DTS has one on each corner... I had swapped out the compressor unit out with a junkyard part before I changed the rear air struts (cheap way to start diagnosing a system you know nothing about) just to see if that was the original problem, before I learned about the sensors on the struts on just the DTS models... I'll probably switch back to the original pump before I start doing further diagnosis (read: lots of diagnosis...)Thanks Darin. Yeah, fixing the automatic level control system hasn't been as easy as I thought it would be, and it's been pretty expensive. Once I'm done, all that will be original will be the wiring and the air lines. I'm still trying to buy a refurbished level control sensor. Still, I want this to work. When the back of the car gets loaded down with passengers and luggage, I want the ride height to be correct.
You mentioned your Caddy is sitting low in the rear. On my car, there is an adjustment on the level control sensor, and a height specification in the shop manual. Maybe your sensor needs adjustment?
