TH200 & 200-4r internals
ddevito
9
Can some one tell me if the 200 trans has most of the same drums ,planets & ring gears (besides the overdrive stuff ) as 200-4R ? I'm aware the pump is different.
g0thiac
915
554
200 4R and 700 both use a tv cable also, which requires more adjusting than what the TH200 and the others have.
ELCAM
926
946
Some things interchange.
The Low sprag is the same.
The input drum shell is the same as the 200c.
ddevito
9
how about direct drum ? seeing cores are cheaper and they take a beating in the 200-4r
