nevermind the tools and crap all over the place... is your fan blade to shroud relationship similar to that pic? with 1/2 of the fan blade in the shroud. and the other half out? if yours is similar, then we could talk about routing...
r.
r.
1. Bleed the cooling system properly - air pockets are the devil. Start by raising the front end of the car ensuring the rad cap is the highest point of the cooling system. Fun fact: hot air rises;
2. Drill at least one 1/8" hole in the outer ring of the thermostat, even if it has one already - helps with the bleeding;
3. Is the factory shrouding/ducting still on the front side of the core support to the grille. Air will follow the path of least resistance which isn't through the radiator's fins;
4. Seal everything around the rad and its core, shrouds, ducting, core support. If you can shine light past it, it is leaking. You can get nice foam from the plumbing section at Home Depot used for pipe insulation and stick on weather stripping. Or use pool noodles;
5. Is the airdam under the core support? If not find or make one, ths helps improve the air flow by improving the low pressure area behind the rad/in the engine bay at speed;
6. Try Waterwetter or a waterless type coolant to improve the boiling point and/or remove surface tension and water pockets; and
7. Get an electric fan. It is 2017. Seriously.
Get a electric fan huh? I guess you didn't read me previous post......Seriously?1. Bleed the cooling system properly - air pockets are the devil. Start by raising the front end of the car ensuring the rad cap is the highest point of the cooling system. Fun fact: hot air rises;
3. Is the factory shrouding/ducting still on the front side of the core support to the grille? Air will follow the path of least resistance which isn't through the radiator's fins;
5. Is the airdam under the core support? If not find or make one, this helps improve the air flow by improving the low pressure area behind the rad/in the engine bay at speed;
