I agreed with most of what he said as well, but I prefer to speak to others as human beings.
At higher speeds, a core support airdam is critical to cooling. When we first started running the 2+2 it would overheat above 125 mph because we didn't have a core support airdam, and pressure would build up behind the radiator and reduce the flow through it.
We put on a 5" deep core support air dam and never had another problem at speed, even at high rpm and sustained WOT.
At the junkyard, grand marquis/Crown Vics have good plastic core support Air dams that can be adapted to a street G-body. Ours is bent Aluminum and Conveyor belt material, but is designed to 170 mph, so its overkill for the highway
