On the injured list with a bum hand after an injury at work today, so I figure I’ll do an update rather than push my luck out in The Skunkworks tonight.
I’ve been spending quite a bit of time out in the shop lately, but haven’t gotten a lot of actual work done yet. It’s been a lot of thinking, measuring, cycling the rear suspension and trying a few different things mostly to determine what’s going on in the back.
I put the car up in the air on stands to install the mock-up driveshaft for determining driveshaft clearance when it’s aired down, and of course one thing led to another to another, to another.
Basically I found that with the back aired completely down, none of the suspension components were resting on the bumpstops. Puzzled by this, I started looking hard at what was holding it up.
Shocks weren’t fully compressed, upper A arms weren’t hitting the trunk floor, lower arms weren’t contacting the frame. So wth was preventing the diff from going higher? Long story short, I found that it was the collapsed height of the rear air bags themselves. They physically can’t get any shorter due to the internal construction of them.
“Hmmm, ok. So that must mean it can get lower if I remove the ‘bags right?” I mean afterall, Shockwaves are available for G bodies for the rear suspension if there’s any real gains to be had here. Expensive, but possibly worth it depending on what I find.
Well, it’s not worth it.
After removing the ‘bags and jacking the diff up as high as it would go and then setting it down on stands under the axle, I only gained maybe 1/2”, if that. So no, spending $1150 USD on rear Shockwaves to gain 1/2” lower is most certainly not worth it IMO. Good news is, now the axle sits on my cut-down bumpstops. So what I’ll do now is pick up another set of bumpstops and cut them down a 1/2” less so that the axle rests on them instead of the ‘bags. The rear wheels sit up in the quarters about 3” as seen in this pic with the outline traced on the quarter, that’s enough to tuck almost all of the tire when viewed from the side.
I still have lots of room inside the wheelwells height-wise to go lower, about 3” with my current wheel and tire combo, but far more things are going to start hitting other things long before that becomes an issue. No, we’re going to start getting into diminishing returns for the amount of work and cost required to get much lower. I’m only looking for a cool stance when it’s aired down, not a “laying rocker panels on the ground” lowrider.
Performance on the road is far more important to me.
I had a real good look around at everything underneath the car, and I think I’m still going to go with my initial plan to remove 1/2 - 1” off of the body mounts. The area that’ll be the closest is the rear upper control arms to the underside of the trunk floor. I believe I’ve got clearance to everything else to afford up to that 1”.
So yeah, that’s the rabbit hole I quickly went down investigating driveshaft clearance. Speaking of which, I am going to have tons of clearance at my rear firewall keeping the stock portion of it from the floor brace back. Even with as large as a hypothetical 4” diameter shaft. (Which I won’t need, looks like 3 1/2” will be more than adequate according to driveshaft critical speed calculators).
Mike was able to get the sheetmetal material I gave him run through the slip roll he has at his work, and it turned out beautifully.
I’m going to have WAY more room for a larger ‘shaft with this one vs the original.
On the transmission tunnel side of things, once I got the car up in the air and was able to have a good look underneath, I was rewarded with nothing but good news. Absolutely everything clears, the tightest spot is between one of the shifter boot screws and the reverse lockout solenoid. Easily fixed by shortening the screws which stick out about 1/2”.
The new trans tunnel was more than well worth the effort.
I got some of the metal finishing done on the top and passenger side, it’s looking pretty good but I won’t be completely satisfied until I can hammer and dolly it out a bit.
As mentioned, the shifter boot is now attached, did it with nutserts and #10 x 32 stainless screws.
As for the transition between the transmission and driveshaft tunnels, I think I’m going to keep the height here where it is. The top of my driveshaft safety loop is going to be too close to the top of the larger driveshaft when it’s aired down, so I’ll keep the height of the trans tunnel where it is and make the top half of the loop taller.
Hell, I might even have to make the entire loop a bit bigger, but I’ll worry about that when the time comes.
On the interior, I’m going to hold off on spraying epoxy on the inside of the floorpans until the body comes off the frame again. I know I’ll probably find the occasional weld pinhole or area that needs repair, and I don’t want to burn the epoxy on the inside if I have to do any welding.
That’s about all I have to report on for now, not much work is likely to happen in the next 2 days, but I’m planning to log in some serious hours on it in the week between Christmas and New Years that I have off.
Hope everyone has a Merry Christmas and a wonderful New Year.
D.
