Moar louder?I'll be that guy....
With the exhaust as short as it is (exiting in front of the rear wheels) as well as the larger diameter it is..... Why run the cut-outs @ all?
Seems like an unnecessary addition.
Well, if I have to explain then you probably wouldn’t understand.
I mean c’mon, just picture it:
Second or third gear on the six speed, wide open throttle, close to 500 ponies and 462 cubic inches of pissed off big block Olds singing through 3” pipes off open headers?
Why not?!?!?
Gotcha. I prefer doing all the same antics w/o the volume @ 11.Well, if I have to explain then you probably wouldn’t understand.
Why not?!?!?
I'm with you on this one.The older I get the less tolerance for noise I seem to have.
Do you have a plan for the H bridge relay that you need to make that switch work? I looked into that for mine and it's pretty much a complicated bummer.And that’s cool too, I fully understand believe me. The older I get the less tolerance for noise I seem to have. But it’s always nice to have the option to run open headers if I want. If nothing else, it’ll be great to have to drown out the idiot tuner kid in his backfiring Honduh at the light next to you.
Also, the cutouts don’t necessarily need to be wide open when used. I plan on wiring them to a momentary toggle switch, so as long as the switch is held, they will open. But that way I will also be able to just crack them open a little bit and change the sound of the car without going full obnoxious if I want.
