Anytime Dana. Me casa et su casa.Happy Birthday Donovan... one of these weekends I'll cruise down and have a cocktail with ya in your garage and tell tall tales
There is and should be clearance between the top of the spring pocket and the underside of the trunk floor. If there wasn't, the two would touch and rub. All the body mounts and trunk floor cushions have been replaced with quality Prothane poly urethane body mounts ensuring the clearances are there and correct. If the clearance isn't there on your car, I would consider the possibility that your mounts are wore out and have compressed over time.Hey man, like what you've done with the rear spring pockets on the frame.
My questions is, is there clearance between the top of the spring pocket and the underside of the body? I thought the two pretty much touch when the body was on the frame, but you're running an airline connection through the top of the pocket and along to the centre of the frame bridge to meet up with the bulkhead fitting through the floor. Also, if you have a fault with the rear bags, you're gonna have to part out the frame and body to get to the bag mount bolts.
Mention of the clamps was actually made in the thread. They are nylon clamps from a company called "Made For You Products" and I got them from Summit Racing. They're available in single and double combinations in many different sizes.Thanks for the reply, it certainly helps when forward planning mine set-up.
The hose/cable clamps you've used along the frame are a really neat solution, are they home-made or off-the-shelf?
nice....what 's that spoiler from?
