In the next couple of pics, there's two things going on. The first thing (and what I really want to point out at this stage) is the skim coat of filler that has been applied and blocked out on the top of the new package tray inside the bead rolled area. Most people probably wouldn't have bothered with this step, depending on how they planned on finishing the area. I however, plan on covering the entire rear firewall and package tray in a nice thin layer of black leather to match and complement the seats and the rest of the interior. Sound deadening will be applied in the future, but to the undersides of the panels, so that I don't lose definition of the bead rolled details. It's for this same reason that no layer of foam will be applied underneath the leather. What all this means essentially, is that the panels needed to be as straight and flat as possible because the leather will not hide any imperfections.
The second thing to see in the following pic is the rear window to trunklid filler panel temporarily mocked up into place. The plan in the future is to eliminate the seams where this factory removable panel meets the tops of the quarter panels. This means welding the panel in, however 1978-80 Cutlass and Regal filler panels are made from aluminum. Not having a TIG welder, but being a fairly resourceful individual, I had you fellow Forum members do a little research for me, and it was found that the '81-88 Cutlass models used a steel one. (Thanks guys, you rock!) Taking a bit of a gamble that the rear window curvatures between the two year styles would be the same or very close, I contacted fellow Forum member O.D.Showtime. He hooked me up with a great condition steel example, and as soon as it arrived, I was test fitting it to the car. (Thanks Kevin, big shout out brother!)
The curvature is not only close, but it is in fact identical. This is great news, as it means I can use the factory chrome trim for the window surround.
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
The shape of the panel where it meets the quarters and how it sits in place is different however, but definitely useable. That will get addressed in the future. For now, here's the relevant pics.
...And test fit with the factory '80 chrome trim.
And guys, I hate to say it, but that's roughly where I left off on this area of the build. It's obviously still not complete, some hammer and dolly work needs to been done on the face of the firewall yet before the firewall sides can get welded in permanently. The flanges of the sides that will be welded to the wheelwells still need completion as well, as does more plug welding and skim coats of filler once its all permanent. What you've read on the progress of the fabrication and installation of the firewall, trunk floor, and wheelwells represents the last year and a half of the work on the car. And to be honest, I'm pretty damn sick of looking at it and working on the same areas for so long.
![Doh :doh: :doh:](https://cdn-0.gbodyforum.com/oldsmilies/doh.gif)
Lol
So it was at this point that the days were getting longer, the weather warmer, and spring was calling. Time to take a much needed break from it. I'm now back to work on the car again at long last after taking the summer off, but I wasn't quite ready to jump back into the same area. I needed a change of scenery!
So that brings us up to the present. Rather than stuffing myself inside the back of the car for the next couple of months again, I decided it was time to finally give the poor girl her "face" back again. It's been about 3 years to this point that the front header panel has been off the car to allow for panel fitment, hood fabrication, body to frame mock-up etc etc. Getting the header fit and back on the car would lead to several other things that I could get closer to being ready for paint, so I decided to start there.
A little bit of back story: This car was originally a Cutlass Calais. This meant it had the square "egg crate" style grilles that were more commonly found on the sedans and wagons. The header panel itself takes only this style of grille. Not the coolest front clip for a hot rod. The 1980 Supreme front end however had the much more stylish "waterfall" style grilles, and looked MUCH better in my opinion. Again, as with the Calais header, the Supreme header will only accept the Supreme grilles. Change the grilles, change the header. Back in the 90's when I first purchased the car, I was fortunate enough to find a Supreme header in the junkyard, but it had been involved in an accident at some point in it's past, and several of the mounting tabs were broken and/or damaged. It sufficed for several years, but during that time I never did come across another one to replace it with. Upon contemplation of this, I realized why. 1980 was the last year of this body style before they changed it (and the header panels) in '81. 1980 was also the first year of the quad headlights in the Cutlass. Prior to this, they were all of the single large headlight per side variety. What all this adds up to is this:
The 1980 Cutlass Supreme front header panel is a
ONE YEAR, ONE MODEL ONLY option. Yup, that's right, GM put all that time, effort, and engineering into creating that header panel to only use it for one year, and one model before discontinuing it forever! Talk about unobtainium!
Fast forward now, to 2010. I came across what is now affectionately known as "The Brown Bomber", my miracle find parts car. When I went to look at purchasing the car off the shady used car lot it was at, the header panel and grilles were obviously the first thing I was interested in. Much to my surprise (and delight), all three pieces were in near mint condition. Considering the asking price of the car by the lot ($1500), and the relative value of the header and grilles to me, I gladly paid the asking price, and got the car home as fast as I could. As far I was concerned, I paid the $1500 for the header and grilles, and got the rest of the car for free! They're that valuable to me. After VERY carefully removing the header and all it's components, they were safely tucked away until I was ready for them. Which is where we're going to pick up next time in the next installment.
I've been working on this area for the last 3 weeks or so, so you're not too far off now from being caught up to date with me. That's when these updates will get much easier and quicker for me to do. I'm REALLY excited with the progress and the mods I have to share with you in the next couple installments, I think it's going to be killer, and I hope you guys agree. I can't wait to be able to start sharing them with you all! For now however, I can only leave you with some sneak peeks and hopefully not give away too much in the process...
'Till next time,
Drive angry, my friends.
![Icon Mrgreen :mrgreen: :mrgreen:](https://cdn-0.gbodyforum.com/oldsmilies/icon_mrgreen.gif)
