Yea I did that distributor rotor test, to test the timing chain...If you are asking what to remove to get to the timing cover, you should stay away from the task you are about to partake on either a gear/chain swap out and or cam. So you pull the cam, then what? I am not aware that the GM cams have any PN stamp on them. Correct me if I'm wrong. If your timing has jumped a tooth and continues to do so, it will get out of timing and at some point will not start if your lucky and don't have the valves kiss the pistons. RPM increase and decrease has nothing to do with timing as you suggest. Are you sure that your distributor is clamped down tightly and NOT rotating?
But that timing cover leak is getting bad...
if this is your daily for work , leave the cam alone or your will be bussing it to work Monday.
what engine are we talking about ? a chevy 305 or 350 ?
I would go with a MELLING timing gear set.........but honestly in today's world ...any brand that you get quickly.
That's about the price range I've seen around too, just didn't know which one...They sell a cloyes double tooth at O'Reillys, I think it was 30$ last I looked at one
yeh if you want to wake up the neighbors when you drive by.Geardrives are pretty accurate and don't stretch.
