Where does the thermostat go in the whole mess of the intake?
Follow the upper radiator hose
It's under the water neck which is also called a thermostat housing.Where does the thermostat go in the whole mess of the intake? Sorry I'm not learned on this topic very thoroughly. And cool, thanks on the bolts and RTV.
For the Q-Jet gasket, get a later type to match. The earlier intakes have a cross over under the front 2 barrels. I have a '67 327 intake with this cross over.The thermostat sits in the intake under the water neck. Get whatever came stock in the 305, 180F or 195F. The spring part or back part of the thermostat sits in the intake. Get a SPREAD BORE (two big holes, two little holes) base gasket for a quadrajet. Don't matter what year, they all used the same type. New air filter if yours is dirty. Mark EVERY line going to the carb or take really good pictures. Parts store should have intake bolts, if not AlloyBoltz (google em) or Summit will have new ones. USE ANTI SEIZE on every bolt! Copper or aluminum. Use thread sealer and antiseize on bolts that will come into contact with water or oil.
Mr. Gasket has a reusable gasket for the thermostat housing. Most parts store have them in the speed goodies section.I personally do not like the chrome thermostat housings. I do like the O-ring design however,, but I find that the housing tends to warp and leak over time.
I went back to using the cast iron OEM type water neck/ housing and never had a problem since.
