finally got the wheels install on the cutlass and I almost had a heart attack. check the tire and frame rail clearance I think I may have about a 1/4 inch of space between them . trying to figure out how I fu..k that up. I've read multiple post of guys with cutlass installing 255/60/15 on 8 inch wide rim without any problem. I got lucky it doesn't rub but not much Clearence. think I may have to add a spacer are something. Just wonder if anyone else with a 87 cutlass having this problem . the car had 20 inch rims when I got it, don't remember the tire size. the rear has air shock and Variable rate springs which I'm planning to swap out to lower the car and soften the ride, As of now there's about 2 inches between the top of the tire and the lip on the wheel well. the rims I purchased was Jeg Sport Torque Wheels.
this is what the rep recommended, not blaming him but I need to make this work
- Size: 15" x 8"
- Bolt Pattern: 5 x 4.75"
- Back Spacing: 4.50"
- Offset: 0
- Center Bore: 83 mm
- Load Rating: 2100 lbs.
