tire and frame clearance
scarborough
309
66
finally got the wheels install on the cutlass and I almost had a heart attack. check the tire and frame rail clearance I think I may have about a 1/4 inch of space between them . trying to figure out how I fu..k that up. I've read multiple post of guys with cutlass installing 255/60/15 on 8 inch wide rim without any problem. I got lucky it doesn't rub but not much Clearence. think I may have to add a spacer are something. Just wonder if anyone else with a 87 cutlass having this problem . the car had 20 inch rims when I got it, don't remember the tire size. the rear has air shock and Variable rate springs which I'm planning to swap out to lower the car and soften the ride, As of now there's about 2 inches between the top of the tire and the lip on the wheel well. the rims I purchased was Jeg Sport Torque Wheels.
this is what the rep recommended, not blaming him but I need to make this work
  • Size: 15" x 8"
  • Bolt Pattern: 5 x 4.75"
  • Back Spacing: 4.50"
  • Offset: 0
  • Center Bore: 83 mm
  • Load Rating: 2100 lbs.
bracketchev1221
1,421
1,665
Sounds about right. I have the same setup on my 80 malibu. I added a 7/32" spacer to both sides to move it out a little.
scoti
1,985
3,423
Texas
Check the measurements on both sides.
The C4L rear set-ups are known to be less than accurate @ times. The same goes for the body in relation to how it sits on the frame. It can be skewed to one side more than the other.
mikester
2,928
3,721
Small town NY
Pretty sure the BS on the 15 x 8" Weld wheels on my 81 Malibu is 3.50. I have 275 60s.
This is the main reason I havent bought tires and wheels for my wagon yet. The 7" rally rims on the back have 4.50 BS and you cant put your fingers between the tires and the frame. I dont know how all these guys are sticking these wide wheels on their cars.
Streetbu
Know it all, that doesn't
3,746
11,639
Central NY
People's expectations and amount they will compromise or settle for things is different. I'm not willing to listen or deal with tires rubbing, at all. Other don't mind if it's only when they have back seat passenger's, or over bumps, or when turning at an angle over a curb. So for one person, and one car, which can vary widely, it may be fine, for a different person, and a different vehicle, may not be acceptable at all.
Rt Jam
598
594
Ontario Canada
1/4" clearance will always be a 1/4" clearance as the suspension compresses. The problem is articulation. Streetbu describes it as angle over a curb.
Think of the axle being parallel to the rear bumper. Now compress one side only and the tire come closer to the middle of the car. The 1/4" will disappear quicking in this scenario.
5,716
12,234
Same wheels on ‘80 Cutlass needed 1/2” spacers to provide 3/8”-1/2” on both sides with a 275/60R15.
Drkuhar
512
913
Girard, IL
I think there is a misconception on the backspacing needed. My wheels are 3.5" back spacing and that is perfect. Everyone i know that has the 4.5 backspacing or around that needs to deal with spacers to get it not to rub.
