Tire rub with new tubular upper control arm
Chevytruc1658
Oct 22, 2011
86
26
North Bend, Washington
Hey everyone,
I have a issue that may be so simple that this question is deemed idiotic but never the less I need some help from y’all, I installed front UMI upper and lower tubular control arms, with Viking coil overs, a 2” drop spindle, and the standard slotted disc brake upgrade from inline tube on my 87 442. I also replaced all the ball joints, torsion bar, idler arms etc. The car is still under restoration and currently has no engine for front clip. I have not torqued any of the ball joints, and left them finger tight as I assumed that once the engine is in that’s when I should get everything torqued down. The control arms were tightened down and torqued. The issue I am seeing is the inside tire is now rubbing against the front side of the upper control arm when in full steering lock. Has anybody had this problem? Could it be because the front end components are not tightened and aligned yet or could it be my wheel? I am running stock 15x7’s.
Thanks
Chevytruc1658
Oct 22, 2011
86
26
Only the front rub, does not touch the back of the control arm.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Arms on the wrong side possibly?
Chevytruc1658
Oct 22, 2011
86
26
I thought about that but I’m pretty sure they are correct as they were labeled when I installed them. Not sure how to tell otherwise either
Chevytruc1658
Oct 22, 2011
86
26
This is the Driver side
Ribbedroof
4,904
7,013
Wellston, OK
Can't comment on the arms hitting, but the ball joints should be tightened when assembled, the control arms should be left loose until the full load (engine/trans/sheetmetal/fluids, etc) is on the chassis. Otherwise, they bushings are going to be preloaded once the weight is on them, which often results in premature wear.
melloelky
4,162
9,569
mass
i have the same uppers/lowers (w/taller BJ exceptions)as yourself.a 1" shorter spring/stock spindles and a 17x7 rim and the lt tire rubs the front of the arm.the cars aligned,assload of miles on it,tracks straight,no wear.i have no idea why it happens.
5,710
12,219
Isn’t that going to correct when he puts some weight (motor) in it?
Or he needs to borrow a couple of Druggles fat ballast women for a minute.
