Torque converter
AlexSUPR
Apr 21, 2016
8
I have a 350 small block and a th350. What torque converter is recommend. Wanting to hit high rpms to pick up a little faster.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,815
Louisville, KY
We need some specs on the engine/rearend to help select a good converter.
What is the lift/duration/powerband of the cam?
What heads are you using?
Carb or injected?
307 Regal
1,667
915
Northern Indiana
I don't know engines well enough to shop for one, but I can tell you I'm using a PATC converter to good effect, in case you need more brands to check out.
lilbowtie
3,460
3,965
Canton Mi
Look at your cam card and it will tell you what stall is recommended and you can push that a little more. You might want to think about changing the rear instead.
