TPI in a Monte Carlo SS
Here's mine. Those skinny little 11in. wide tires I have on back don't stand a chance. I need to get some burnout pics sometime.
That looks great. I want to do the same thing. I am using the old belt drive system for a while. I have just had new lines made and a brand new AC compressor in it. When I do the 383 stroker swap I will probably go with the serpentine belt system. Did you go with the new fuel tank and pump or did you go with the inline fuel pump?
I used the stock tank. I put in different sender and intank pump. My tank doesn't have the sump, but as long as you keep gas in it your ok.
I have a stock trans-am motor in mine.
What did you use for a sender and intank pump? Was it for a 4.3L V6 fuel inject Monte Carlo? Just curious.
I am getting ready to throw my tpi setup on my cutlass and tried to get the sending unit for the efi monte 4.3 and cant seam to find it anywhere......
I had bought mine off of Ebay but the same guy doesn't have any more listed. Napa had said they could order one for me also if I remember correctly it was about $278.
If you want the tank and sender for fuely, then 4.3 is what to look for.
I'm using the iroc pump with the 4.3 sender in a stock non baffled tank.
$278??? wow, i will wait till i find one in the salvage yard or go for a linline if it costs that much.
