Well Picked up the next engine and it was done so here is my parts list for the swap so far.
1. Howell Engine harness for the TPI in a G-body
2. Edelbrock High Flow intake (port matched)
3. SLP ported and polished intake runners.
4. TPIS 58 MM throttle body
5. Camaro serpentine brackets.
6. Edelbrock Headers (already had) but Jet Coated with extreme sterling silver.
7. 3" exhaust pipe leaving the CAT shell for emissions (just has to be there)
8. Granitelli adjustable MAF
9. Fuel sending unit and tank from a 86 TBI Monte
10. SS Fuel lines custom bent by Fine lines
11. AN fuel lines to connect all the metal lines and fuel filter.
12. Not sure of the fan set up I am using yet I have out of a Taurus SHO and a dual fan out of a Concord.
13. Ported/polished upper plenum with siamese ports.
14. 140 Amp alternator
15. Core support for a early 80's Olds.
16. Energy Suspension urathane motor mounts.
17. MSD 6AL spark box.
Engine
1. 350 4 bolt main 30 over
2. Scat Stroker Crank
3. Scat H-beam rods
4. Lunati Vodoo 60111 asymmetrical cam
5. Comp Cams retro fit Roller lifters
6. Crane center bolt full roller rockers
7. Speed Pro Flat top hyperutectic 2 valve relief pistons ( should make
10.3:1 compression ratio.
8. AFR 195CC Elimintator heads 65CC comb chamber 2.05/1.60 valves
9. March under drive kit.
10. MSD Distributor
11. High flow Aluminum water pump
12. Thrust bearing.
A/C
1. Buick Grand Prix Condensor
2. Monte Carlos Accumulator
3. Buick Grand Prix Hard A/C Line
4.
Caprice rubber line (have not tried yet just looked like it may work)
5. 89 Camaro Compressor
6. Monte Carlo Evap
This is all I can think of for now. I still need to stick all of it in the car but I have one heck of a parts pile.
