The only difference I know of from the 305 to 350 was the injector size. I don't know if you can visually check it without pulling an injector though. I do know they have ID numbers on the injector body if you can find it. If you run a hot chip without many internal mods the 305 injectors should be sufficient for street use, just let the guy doing the chip know if you have the 19lb or 21lb injectors. Also the Vette had a smooth finish on the intake tubes vs. the F-bodies textured tubes.85 Cutlass Brougham said:Just a quick question: How can you tell a 305 from a 350 TPI? I saw one in an old Camaro on my last junkyard trip and was intrigued. I figure maybe I could hook it up using a Megasquirt EMS instead of using the whole GM wiring mess.
